Shared Parking Bug?
Discussion in '3CX Phone System - General' started by danoh, Oct 7, 2010.
  1. danoh
    Aug 18, 2010
    56
    Seems that if you pick up a call that was parked in a shared parking slot (SP0 for instance), you can not re-park that call in the same shared parking slot that you picked it up from, you must choose a different shared parking slot.
    I'm using Cisco SPA-504g and SPA-509g phones with the same behavior on both.
    Is this intended behavior, or a bug?
  2. diversified1
    Nov 19, 2009
    5
    i am having this problem too - any ideas?
  3. dsnyc
    Aug 30, 2010
    34
    Yes I am having this problem too.
    I am evaluating 3CX and so far this is preventing me from purchasing it.
  4. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Hi, are you pressing the button Xferlx on Cisco phone when you park the call to SP0?
  5. danoh
    Aug 18, 2010
    56
    No, I bxfer to the shared parking slot.
  6. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Different Cisco models have different methods of transfers.
    Now to transfers calls to the Shared Parking Orbit you need to use the button xferLx.
    For Example if you are using 504G - you will need to use button xferlx to place the call in the shared parking orbit.
    Now 509G - you can also place the call directly without pressing xfer or xferlx and just select the blf which has the SP, but still if you want to park again the same call to the same SP again you still need to select xferlx.
    So I would just use Xferlx to park calls to SP.
    Note this must be ALSO configured properly and with the latest firmwares.
    Thanks and Regards
