Shared parking using a Yealink T26
Discussion in '3CX Phone System - General' started by karingal, Dec 22, 2011.
  1. karingal
    Oct 19, 2011
    11
    I have set up shared parking on our Yealink T26 phones using BLF buttons.
    I can successfully park a call. When I pick up the parked call, I can only do it when hands free (I can then pick up the handset).
    If I try to pick up the call with the handset lifted up, nothing happens when I push the BLF button.
    Is this how it's designed to work or is there a setting we need to change?
    Cheers Mark
  2. willow
    willow Member
    Mar 1, 2011
    471
    Upgrade the firmware on the phone. This is a phone issue and not 3cx.
