sharing phone with other people
Discussion in '3CX Phone System - General' started by mylove4life, Jan 18, 2010.
  1. mylove4life
    mylove4life New Member
    Jan 7, 2010
    165
    Hi all, ok 3cx masters, what do you all do when you have a company that has shifts and want to have the phones reflect that. Is there a login system that anyone has seen?
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Check the feature requests forum under HotDesking. Lots of requests for this functionality.
  3. mylove4life
    Jan 7, 2010
    165
    Will do.... I'd like it to be able to have a user and password for each person, so when they go to a desk just login and it nows who you are ect...
  4. andymars
    Jan 12, 2010
    47
    fyi http://www.3cx.com/forums/hotdesking-feature-11814.html
  5. mylove4life
    Jan 7, 2010
    165
    I'd rather have the ext. the same on the phones at all times. When someone sits at that desk they login to that phone and it picks them up being there. This is the way shifts would work.
  6. andymars
    Jan 12, 2010
    47
    they would login to the phone in a 'hotdesking' scenario, but i tend to think of extensions as individuals e.g. John has ext.123. from what you said, if you want the extension number to stay the same just setup an extension as 'Shift Office = 123'. maybe what you want is a ringing group for everyone on the shift, then have the individuals login to the phones (then they can pickup calls made to the ringing group).
  7. mylove4life
    Jan 7, 2010
    165
    Something like that, but I'd still like the person to be able to sit at any phone and login to the phone. I think the ext. should be the same all the time.
