Show agent queue status on yealink
Discussion in '3CX Phone System - General' started by indigoboy, Jan 30, 2013.
  1. indigoboy
    Oct 22, 2012
    Is it possible to show the queue status of an agent on a yealink phone? Maybe by a DSS Key or the MWI? My users want to see if they are logged in (and not every one has a PC).
    Regards
    Alex
  2. kevin
    kevin Member
    Nov 23, 2006
    316
    Hi Alex
    Unfortunately this is not currently possible. You can log this as a feature request here:
    https://apps.facebook.com/threecxideas/
  3. TS-TomBale
    Jun 2, 2016
    I know this is an old thread but does anyone know if this is now possible? Would be great to see if you are in\out of the queue without using any software.
  4. jholcombe
    Jul 9, 2014
    79
    I just ran into this problem as well. An agent logged out for lunch and forgot to log back in. It would be very helpful if there was some kind of indicator on the phone itself, for users who don't have access to 3CXPhone.
    Thank you,
    --John
  5. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,379
    84
