show Answer Dialog
Discussion in 'Windows' started by Jazzar, Nov 19, 2008.
  1. Jazzar
    Nov 14, 2008
    31
    Hi all
    Quick question , I just evaluating the free version at the moment and have the 3CX client set to "show answer dialog". When an extention is called this dialog shows the ext no that's calling (i.e 101).
    Is ther anyway to show the persons name instead of their ext no.
    Sorry if this is a dumb question, but I'm new here
    Jim
