Show Caller Details when Attended Transfer
Discussion in 'Ideas' started by DamianCorr, May 12, 2017.
Show Caller Details when Attended Transfer 5 5 41votes
5/5, 41 votes
My First Feature Request. Do you think its a good request?
Poll closed Dec 12, 2017.
  1. Yes
    16 vote(s)
    100.0%
  2. No
    0 vote(s)
    0.0%
  1. DamianCorr
    Apr 26, 2017
    10
    8
    We have just deployed 3CX v15 Pro in our Call Centre which is an all windows softphone deployment and we have just discovered that when our team of receptionists use attended transfer when the call is transferred the windows softphone client shows the details of the extension that transferred the call to them, not the caller they are speaking too.
    Blind transfer does show the details of the caller who has been transferred but not attended transfer which works differently.
    Why would anyone want to see where there call was transferred from!?!? Im sure if you search long enough you will always find someone who wants that feature but i would imagine the majority of 3CX users would want to know who they are speaking too not who transferred the call to them.
    Is there any possibility to get this resolved any time soon?
    Kind Regards
    Damian
  2. GCollis
    Dec 11, 2014
    39
    7
    Totally agree, the ID of the call being transfered also does not show in the call history so the user is unable to then add as contact etc.
  3. nicor
    Jan 31, 2017
    7
    How is this not a default feature of 3CX? You have to have the correct number in the call history! Attended transfers are useless at the moment. We have to first call the person on a second line, then make a blind transfer after. Very annoying.
    DamianCorr likes this.
  4. RTV
    RTV
    Mar 2, 2017
    9
    Probably the most asked request by our clients.
  5. mindstone
    May 20, 2010
    A view Minutes ago i had a call with a customer using DATEV Plugin and Multine TAPI - same issue. A call from another ext. is attended transfered. in DATEV it shows the caller id of the internal ext. After transfer there is still the number of the transfering ext. not from the external caller. Any Ideas?
    Regards,
    Oliver
  6. timmbo
    timmbo New Member
    Aug 25, 2017
    107
    49
  7. Gregor Streng
    Mar 22, 2018
    9
  8. Jon Uhlmann
    Mar 22, 2018
  9. TP_
    TP_
    May 15, 2018
    47
    5
  10. sigma
    Aug 27, 2017
    20
    yes highly appreciated - because this is always requested from customers !!
  11. Paul39
    Jun 12, 2018
  12. Tifoso
    Oct 17, 2017
    58
    11
  13. Benedikt Machens
    Feb 14, 2018
    44
    12
    +1
  14. sperlkrieglmeier
    Feb 12, 2018
    8
  15. mkb
    mkb
    Dec 14, 2015
    14
  16. mcbsys
    mcbsys New Member
    Oct 8, 2008
    205
    23
    I'm testing this now with 15.5 SP5. Blogged here. Seems that attended transfers do eventually show the external CallerID, after the transferring station presses the Transfer button to complete the transfer. Can anyone confirm that the final station does eventually see the external CallerID?
    Also, for some reason, when the transfer completes, 3CX Phone is raising two identical Connection events within about a tenth of a second, causing some issues with my application. Is this a bug?
  17. SKDamon
    Aug 6, 2018
    21
  18. Neturius
    Dec 8, 2016
    23
  19. sentrianjames
    Feb 19, 2018
    18
  20. info@matic-tec.de
    Mar 25, 2008
    36
    22
