Show current extension status in Webadmin
Discussion in 'Ideas' started by Sommer, Jan 14, 2019.
Show current extension status in Webadmin 5 5 2votes
5/5, 2 votes
  1. Sommer
    Oct 20, 2017
    5
    Hello.
    I think it would be great if you could see the current status of an extension (e.g. Available, Out of office, etc.) in the webadmin under extensions.
    This would make troubleshooting in some situations way easier.
    For example:
    Customer accidentially switched his status, therefore other forwarding rules are activated.
    To find this out, you'd have to configure your own phone or client, or log in to the webclient which can be hard sometimes if you don't know their webclient password.
    It would be easier if the current extension status is displayed in the webadministration, maybe another colored point next to the one that states if the extension is registered? (pic related)
    Thank you.
    Best regards,
    Sommer
