Show DID called instead of caller ID
Discussion in '3CX Phone System - General' started by Ben C, Oct 14, 2014.
  1. Ben C
    Oct 14, 2014
    71
    Hi. We have several DIDs. When a call comes to a specific DID, we need to acknowledge which DID was called, instead of who called. That's because we have to answer based on the DID the call came for. How can I do that for a few DIDs?
    I have been playing with 'VOIP Provider' > 'name' > 'Source ID' > 'Source identification by DID' > 'Add DID' > chose 'SIP Field containing DID numbers', but no luck so far. Is this the right place?
    How can I do this?
    Thank you
    Ben
    11,277
    360
    I think that a lot of users pass the calls through a ring group (or queue), and pick up an identifying name there. The name should be kept short ,as some devices do not have the ability to show all information (CID number/name and RG name) resulting in truncation.
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,586
    309
    Just put the DID into the DID rules and setup according to the provider (Source ID, etc). The DID name will show up.
    Ensure the Prepend option is on as well.
  4. Ben C
    Oct 14, 2014
    71
    Hi craig
    Thanks for the reply.
    I can't find the "Prepend" option.
    The manual says:
    "The DID name can be pre-pended or appended to the Caller ID so as to identify on which
    number a caller has called. You can enable this from the Settings > General > Global options page
    under ‘Append/Prepend name to caller ID’." but it's not there...
    I have V12, SP6, 37098.738
    Thank you
    Ben
      File size:
      40.5 KB
      950
  5. Ben C
    Oct 14, 2014
    71
    I got it.
    ...Settings > General > Global options.
    First tick the "Add Queue, Group and DID names to Caller ID" to have "Append/Prepand name to Caller ID" shown
      File size:
      33.5 KB
      948
