Show Extensions Queues in Webmanagement
Discussion in 'Ideas' started by mortenjorge, Aug 8, 2017.
Show Extensions Queues in Webmanagement 5 5 2votes
5/5, 2 votes
  1. mortenjorge
    Apr 1, 2015
    59
    12
    When checking "User Status" in the 3CX Webmanagement, you see all queues as one single Line.
    I think it would be much better, if we could control every single queue separately.
    At the moment, i need to log on of their extension on their 3CX, so i can use the Switchboard, to log on/off
    I was thinking something like this picture.
    [​IMG]
    Thanks!
    jed likes this.
