Show extensions up status in the new partner portal
Discussion in 'Ideas' started by OCWI, Jun 11, 2017.
  1. OCWI
    OCWI New Member
    Jan 17, 2017
    161
    46
    I like the approach to the redesign of the 3cx partner portal.
    I also like that it shows the red/green status for the auto backup status.
    One thing that would be really helpful is showing under the extensions colums "Extensions up" vs total number of extensions.
    That way we can easily see who's /if any border controllers have crashed over the weekend.
