Show number instead of incoming rule name
Discussion in '3CX Phone System - General' started by nitramz, Aug 12, 2016.
  1. nitramz
    Aug 3, 2016
    8
    My Yealink T46 shows the "incoming rule name" first, before showing the caller number.
    How can i change this?
    11,079
    324
    3CX has the ability to show a Ring Group, Queue or DID name before or after the caller ID, or not show it at all.
    Here is one post on the subject.
    viewtopic.php/post178571.html?p=178571
    Where it is changed may depend on where it is being introduced (RG, Queue, or DID), and what version 3CX you are using.
