Show Ring Groups in Switchboard
Discussion in 'Windows' started by ahren, Jun 17, 2016.
  1. ahren
    Jun 2, 2015
    16
    I am trying to get my staff to start using the switchboard to transfer calls, but I can't get ring groups to display in Switchboard view. Is this possible?
    I am running 3CXPhone for Windows 14.0.49169.0
    I have enabled "Show unregistered extensions" in the Switchboard settings, which I could have sworn worked on a fresh installation yesterday, but I uninstalled 3CXPhone without thinking and haven't been able to reproduce it.
    I feel like I'm taking crazy pills.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
    Hello there,
    Ring groups are not visible through the switchboard but maybe you could try using queues where transfer calls can be made if the users have the rights to do so.
    You can give them rights by choosing an extension from the extensions menu and navigating to the Rights tab. The first 5 options must be selected to be able to perform a transfer through the switchboard.
  3. ahren
    Jun 2, 2015
    16
    Ok thanks! I'll give it a shot and post back with the results.
  4. ahren
    Jun 2, 2015
    16
    Unfortunately the virtual extensions used by Call Queues also do not show up in Switchboard regardless of extension rights. I created a work around by creating a "dummy extension" that forwards calls to the specified ring group after being unanswered for 1 second. So far in my testing this is working extremely well.
