Show status in admin console
Discussion in 'Ideas' started by Antoine A. Telerys, Jun 21, 2017.
Show status in admin console 5 5 5votes
5/5, 5 votes
  1. Antoine A. Telerys
    Jan 31, 2017
    17
    Hello guys,
    Could it be possible to show every extension statuses (away, DND, etc...) within the administration console ?
    This would be perfect for level 1 debugging.
    Thanks a lot.
  2. bbaker73
    bbaker73 New Member
    Nov 27, 2015
    142
    25
    In the extensions list, you can highlight an extension, then press the Status button to see their current status, queue status, and change them. It would be nice if this was displayed in the extension list for all extensions without having to click Status.
  3. Paul Omans
    Dec 2, 2016
    86
    36
    Thank you for posting this! I was not aware that seeing the status in this way was possible. I agree that it would be helpful to have the same "at-a-glance" display that V14 had for level 1 debugging purposes, and display the queue status and extension status in the extension list, however I am worried that this could lead to a "cluttered" display, and if that's the opinion of the 3CX devs, I'm perfectly OK with only having the "status" button available to see and change the extension and queue status.
