shutdown 3cx
Discussion in '3CX Phone System - General' started by spec, Sep 29, 2006.
  1. spec
    Sep 8, 2006
    51
    Is there a quick way to shutdown the whole of the 3cx system with out going in to the task manager and Manuel shutting down all the systems?
    thanks
  2. 3CXsupport
    3CXsupport New Member
    Aug 21, 2006
    193
    Thank you for the feedback!
    Currently there is no start/stop button or so. You can go into the services control (start -> run -> services.msc ) and stop the services individually.
