Shutting down 3Cx
Discussion in '3CX Phone System - General' started by Vincent Bezzina, Nov 19, 2007.
  1. Vincent  Bezzina
    Nov 12, 2007
    How can we shutdown 3CX compleltly - without having to hunt down the various processes in the task manager. We are in the process of moving 3CX to its final destination server - and it would be very useful to know how to turn it off when required.
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Hi Vincent,
    You can create a icon call "STOP 3CX" at your desktop then link to the batch file as below:
    rem *** Batch file for STOP 3CX ****
    net stop "3CX PhoneSystem"
    net stop "3CXPhoneSystemWebServer"
    net stop 3cxivr
    net stop "3CX PhoneSystem Media Server"
    net stop 3cxvboxmgr
    net stop "3CX PhoneSystem Database Server"
    Then create another icon call "START 3CX" at your desktop then link to the batch file as below:
    rem *** Batch file for START 3CX ****
    net start "3CX PhoneSystem Database Server"
    net start 3cxvboxmgr
    net start "3CX PhoneSystem Media Server"
    net start 3cxivr
    net start "3CXPhoneSystemWebServer"
    net start "3CX PhoneSystem"
    Finally, you had been created 2 icons at your desktop (STOP 3CX and START 3CX).
  3. silentfun
    silentfun Member
    Dec 11, 2006
    364
    for v4 / v5
    for V4 / V5 you can use the following (it includes the faxserver)
    net stop 3cxivr
    net stop 3cxvboxmgr
    net stop "3CX PhoneSystem FAX Server"
    net start "3CX PhoneSystem FAX Server"
    net start 3cxivr
    splitting them for simple start/stop
