- Joined
- Sep 1, 2017
- Messages
- 3
- Reaction score
- 0
I'm trying to connect a Siemens HiPath 3770 to a 3CX server via a SIP Trunk (no auth). Outgoing works great, incoming not so much.
IP of 3CX : 192.168.1.168
IP of Siemens : 192.168.1.101
Call Source identification is enabled with Contact "Host Part' -> "GWHostPort", Use both is disabled (if I enable it I get "Unidentified incoming call. Review INVITE and adjust source identification").
There's 2 scenarios :
1. Inbound parameters / Caller Number/Name Field Mapping all at Leave Default Value. With these settings the call will ignore all my Inbound Rules and is always routed to the Catch All destination I have setup in Trunk Setup.
2. Inbound parameters -> Caller Number / Name Field Mapping -> "CallerNum" caller's number -> Set to Request Line URI: User Part. The call follows the Inbound Rules and delivers the call to the right extension but the caller ID shows up as CID : DID so if I'm calling from 11111111 to DID 222 in the 3CX client I see a call from "1111111 222" and I can't call it back.
Please let me know if there's a need for additional information and thank you for taking a look at this (whoever you are).
Code:
09/11/2017 4:24:05 PM - [CM503010]: Call(C:192): Making route(s) from Line:10002<<728XXXXX to <sip:[email protected]:5060>
09/11/2017 4:24:05 PM - [CM505003]: Provider:[Siemens] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [HiPath 3000 V8 M5T SIP Stack/4.0.26.26] PBX contact: [sip:[email protected]:5060]
09/11/2017 4:24:05 PM - [CM500002]: Call(C:192): Info on incoming INVITE from Line:10002<<728XXXXXX:
Invite-IN Recv Req INVITE from 192.168.1.101:5060 tid=a97be6d5bb537f176.b965d8ede5653a1a9 Call-ID=1d850691a2a21a43:
INVITE sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.101:5060;branch=z9hG4bKa97be6d5bb537f176.b965d8ede5653a1a9;rport=5060
Max-Forwards: 70
Contact: <sip:[email protected]:5060>
To: <sip:[email protected]>
From: 728XXXXXX<sip:[email protected]>;tag=428a04e3a0
Call-ID: 1d850691a2a21a43
CSeq: 22144 INVITE
Session-Expires: 1800
Min-SE: 90
Allow: INVITE, ACK, OPTIONS, BYE, CANCEL, REGISTER, REFER, INFO, PRACK, UPDATE
Content-Type: application/sdp
Supported: timer
User-Agent: HiPath 3000 V8 M5T SIP Stack/4.0.26.26
P-Asserted-Identity: <sip:[email protected]>
Content-Length: 362
v=0
o=MxSIP 0 627345659 IN IP4 192.168.1.101
s=SIP Call
c=IN IP4 192.168.1.101
t=0 0
m=audio 29100 RTP/AVP 8 0 18 4 98 99
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=rtpmap:4 G723/8000
a=rtpmap:98 telephone-event/8000
a=rtpmap:99 red/8000
a=silenceSupp:off - - - -
a=fmtp:4 annexa=no
a=fmtp:98 0-15
a=fmtp:99 98
a=sendrecv
09/11/2017 4:24:05 PM - [CM503001]: Call(C:192): Incoming call from Line:10002<<728XXXXX to <sip:[email protected]:5060>
09/11/2017 4:24:05 PM - Line limit check: Current # of calls for line Lc:10002(@Siemens[<sip:[email protected]:5060>]) is 1; limit is 10
Code:
09/11/2017 4:33:09 PM - [Flow] Call(C:193): has built target endpoint: Extn:311 for call from L:193.1[Line:10002<<110]
09/11/2017 4:33:09 PM - [Flow] Target endpoint for 311 is Extn:311
09/11/2017 4:33:09 PM - [CM503010]: Call(C:193): Making route(s) from Line:10002<<110 to <sip:[email protected]:5060>
09/11/2017 4:33:09 PM - [CM505003]: Provider:[Siemens] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [HiPath 3000 V8 M5T SIP Stack/4.0.26.26] PBX contact: [sip:[email protected]:5060]
09/11/2017 4:33:09 PM - [CM500002]: Call(C:193): Info on incoming INVITE from Line:10002<<110:
Invite-IN Recv Req INVITE from 192.168.1.101:5060 tid=f47658eb712e4bb3e.4caae0eea1fc73d94 Call-ID=1d82ec77fc16adbe:
Via: SIP/2.0/UDP 192.168.1.101:5060;branch=z9hG4bKf47658eb712e4bb3e.4caae0eea1fc73d94;rport=5060
Max-Forwards: 70
From: 728XXXXXX<sip:[email protected]>;tag=e01523c3e9
Call-ID: 1d82ec77fc16adbe
CSeq: 2277 INVITE
Min-SE: 90
Supported: timer
Content-Length: 362
v=0
o=MxSIP 0 999390257 IN IP4 192.168.1.101
s=SIP Call
t=0 0
a=fmtp:4 annexa=no
a=fmtp:98 0-15
a=fmtp:99 98
a=sendrecv
09/11/2017 4:33:09 PM - [CM503001]: Call(C:193): Incoming call from Line:10002<<110 to <sip:[email protected]:5060>
09/11/2017 4:33:09 PM - Line limit check: Current # of calls for line Lc:10002(@Siemens[<sip:[email protected]:5060>]) is 1; limit is 10
