Siemens Gigaset Cordless Phone w/Hybrid IP/Landline (A580IP)
Discussion in '3CX Phone System - General' started by dvs4man, Nov 11, 2009.
  1. dvs4man
    Oct 5, 2009
    50
    Has anyone got this type of phone working with 3CX? Curious if this type of phone would work with the 3CX system.
    Let me know if anyone has tried it.
    Thanks.
  2. Cjay
    Cjay New Member
    Feb 24, 2007
    190
    This unit looks very like the S450IP (according to the Gigaset compatability checker) - which I have and which works fine on 3cx as an extension.
    I have mine set so incoming PSTN (phone line) calls ring the Gigaset directly (but in my case the incoming calls also go to 3cx as a VoIP call via a SPA3102 ATA. However I do not route this incoming call back to the Gigaset extension or you would get 2 simultaneous but identical incoming calls arriving on the handset from different routes!).
    I have the Gigaset set to default outgoing calls via VoIP (i.e. route to 3cx), however if you prefer you can manually select whether an outgoing call should be via VoIP or PSTN. I prefer to let 3cx decide how to route an outgoing call based on my rules.
    Hope this helps.
    Cjay.
  3. dvs4man
    Oct 5, 2009
    50
    Thanks. It helps. I would use one of these handsets, among many others I would purchase, as extensions inside a church and school. I would route it through the 3CX system and connect with a VOIP provider like Callcentric or Broadvoice.
    I assume you have it setup so that each phone is an extension of the 3CX system, and that you could also callout or do internal call transfers the same way?
    If so, do you have a setup you could share?
    Let me know.
    Thanks.
  4. cb
    cb
    May 9, 2009
    8
    hello,
    i tried this phone with 3CX V8 and it's working fine but i didn't try to transfer calls. I used the config of 3CX made for the C470IP.
    good luck
    Cyrille
  5. xxxomxxx
    Oct 5, 2007
    11
    works fine for me...
    Full SIP In/Out with several lines with 3cx as sip-pbx and Sipcall as a provider. Very easy setup, works great.
    cheers
    Cobra
  6. dvs4man
    Oct 5, 2009
    50
    Thanks Cobra. I just got the A580IP yesterday, and got my 3CX reconfigured to use the handset, and followed the C470IP guide. I am using Broadvoice as the provider, since they can transfer our number to them from a current Landline.
    I can receive calls fine, but I cannot make calls. I get the 403 error in the Server Activity log.
    The Ports/Trunks status is green, as well as the Extension Status. So it seems all is connected well.
    I have used no outbound proxy, and tried using Broadvoice's proxy.nyc.broadvoice.com, with the same results.
    I assume since the Ports/Trunks status is green, the authentication is ok with the proper user account from my end to Broadvoice.
    Here is the logs. Let me know if anything is not right.
    07:53:00.862 [CM503008]: Call(3): Call is terminated
    07:53:00.808 [CM503020]: Normal call termination. Reason: Forbidden
    07:53:00.807 [CM503016]: Call(3): Attempt to reach <sip:99999999999@192.168.0.198;user=phone> failed. Reason: Forbidden
    07:53:00.801 [CM503003]: Call(3): Call to sip:99999999999@sip.broadvoice.com has failed; Cause: 403 Forbidden; from IP:147.135.20.221:5060
    07:53:00.714 [CM503025]: Call(3): Calling VoIPline:99999999999@(Ln.10000@broadvoice)@[Dev:sip:sip.broadvoice.com:5060]
    07:53:00.565 [CM503004]: Call(3): Route 1: VoIPline:99999999999@(Ln.10000@broadvoice)@[Dev:sip:sip.broadvoice.com:5060]
    07:53:00.563 [CM503010]: Making route(s) to <sip:99999999999@192.168.0.198;user=phone>
    07:53:00.559 [CM505001]: Ext.10: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [A580 IP022140000000] PBX contact: [sip:10@192.168.0.198:5060]
    07:53:00.541 [CM503001]: Call(3): Incoming call from Ext.10 to <sip:99999999999@192.168.0.198;user=phone>
    07:51:56.459 [CM504004]: Registration succeeded for: 10000@broadvoice
    07:51:56.151 [CM504003]: Sent registration request for 10000@broadvoice
    07:51:54.043 [CM504004]: Registration succeeded for: 10000@broadvoice
    Thanks.
  7. aveiser@veiser.de
    Dec 23, 2008
    23
    There is an IP 147.135.20.221 from which network??
  8. dvs4man
    Oct 5, 2009
    50
    That, I thought, was broadvoices sip.broadvoice.com address. But that is 147.135.32.221. I am not sure what it is, unless it is forwarded from sip.broadvoice.com to that address?
  9. dvs4man
    Oct 5, 2009
    50
    The connection is working fine now. Thanks. It was on broadvoices end.
