Siemens Optipoint 410 economy
Discussion in '3CX Phone System - General' started by magaspar, Aug 29, 2007.
  1. magaspar
    Aug 29, 2007
    Good morning,
    I have several optipoint 410 economy but without SIP firmware... I can't find any FW compatible in order to upgrade it to handle SIP accounts. Still, since it's a IP phone, is it possible to connect it to 3CX with any particular configuration? Has anyone tested it or has a compatible FW to make it work?
    I read something about particular models. These ones are S30817-S7212-A107-xx
    Thank you.
