Silence on Call transfer Waiting?!?!
Discussion in '3CX Phone System - General' started by mhanson, Jan 14, 2009.
  1. mhanson
    mhanson New Member
    Nov 6, 2008
    186
    On a new install, my system works just fine.
    One thing I found odd is that when I receive calls from the outside, they can get to my digital receptionist, then when they enter a choice, I get the your call is being transferred message, but then nothing. The Call will transfer through, but there is no ringing sound or music, just silence until the recipient picks up. This is very misleading to the customers calling in, as the silence leads them to think that they have been cut off.
    Is there a way to set the sound, or make the line ring?
  2. alexmallia
    alexmallia New Member
    3CX Support
    Aug 4, 2008
    130
    When the call is being transferred, you should hear the music on hold.
    Please ensure that the music on hold has been set up correctly from the 3CX configuration -> Settings-> General.
    Ensure you can click on play and the music file is played correctly on the 3CX machine.
    regards
  3. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Hi, mhanson
    As far as your problem cannot be indentified basing on your information (see guidelines http://www.3cx.com/forums/forum-rules-read-to-get-answers-93.html ) then, in addition to Alex's recommendations, try to set "Supports re-Invite"=off for entity(PSTN gateway, VoIP provider, Extenstion) which doesn't play "music on hold" that is provided by PBX.
  4. Rusty23
    Sep 15, 2011
    5
    Thanks SY,
    I had a similar issue, a call would come in, my digital receptionist would give them the options, they would make their selection it would ring the correct queue and play the hold music. When the operator chatted for a while before popping them back on hold it would say "you are being placed on hold" but then dead silence.
    This solved the problem I was having but took me a while to find!
    I experienced this issue on 3CX V10
