Silent DND status set
Discussion in '3CX Phone System - General' started by SvenK4, Mar 23, 2017.
  1. SvenK4
    Mar 23, 2017
    Currently have CISCO 508G phones, half of them are silent when the DND softkey is pressed. The other half have an audible announcement that states "Do not disturb status set." I've searched for where this setting is located but it would be fantastic to turn this audio prompt off.
  2. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    I've never heard that ... I'm thinking it's a setting in the Cisco and not 3cx.
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
    Actually this it a 3CX prompt. You should hear it from every phone if you dial *32 (DND status dial code).
    Are all your phones provisioned on the same PBX with the same firmware and templates?
    Maybe speaker volume is off in the devices you do not hear this prompt?
  4. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    haha oops I had misunderstood - I was under the impression callers were hearing that when they dialed some extensions that are set to DND.
  5. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,325
    253
    I saw this back in v10 on Yealink. Some of the phones would dial and hang up... no announcement heard - but status was changed.
    It wasn't a deal breaker - but folks had trouble just trusting that the status change did happen.
