Silent install of 3CXPhone for Windows v12
Discussion in 'Windows' started by kthornton, Jan 20, 2015.
  1. kthornton
    Jan 20, 2015
    Can anyone post the switches needed to do a silent install of the 3cxphoneforwindows12.msi? For example, I would like it to install with the typical install options and install the MS redistributables, if needed, all with no user intervention required.
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,397
    273
    Drop to Command Prompt.
    Run the MSI with /? to get options.
    Code:
    c:\downloads> 3cxPhoneforWindows125.msi /?
    Not sure how the config file would work for the individual extension setup.
