Simple setting of Forward profile
Discussion in 'Call Flow Designer' started by zweimeter2, Jan 22, 2018.
  1. zweimeter2
    Jan 22, 2018
    Hi!
    Is it possible to set forward profile of another extension via set dn ?
    So forward profile is not a variable in dn?
    Or only via Call Control API?
    thanks
    Martin
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,616
    126
    Hi Martin!
    The component to set a DN property will not help you with this. That is to set a property in a key-value dictionary, but not to set the C# properties of the objects. So you need to do this using the 3CX Call Control API.
    Kind regards,
  3. zweimeter2
    Jan 22, 2018
    For anyone interested in this, attached you'll find a sample project for that. Kudos to @edossantos
    Marc Mohring likes this.
  4. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Few comments regarding setStatus.cs.
    1. remove call to Refresh() method. It is not necessary and executes expensive procedure which does nothing helpful in the method.
    2. The snapshot, which is taken from PhoneSystem.GetDNByNumber(), is used locally. So the snapshot can be disposed right after Save(). better to change code to something started with
    try
    using(var dn=PhoneSystem.Root.GetDNByNumber(extension))
    ///cast to the extension assign new profile, call to save
    return true;
    catch
    return false;
    3. use try ... catch ... to avoid the unnecessary handling of the exceptions in user code. "upcast" of DN to Extension, usage of First() and the call to DN.Save() method are potentially generate an exceptions which may unexpectedly interrupt script which calls setStatus. I think that it is enough to return true/false to inform caller whether the current status was applied. (see above)
