Simultaneous call
Discussion in '3CX Phone System - General' started by chlliew, Mar 6, 2014.
  1. chlliew
    Mar 4, 2014
    8
    in 3CX .. there is a term called "SC" - Simultaneous Calls
    with a 16SC license, we only have 16 SC.. that mean only 16calls can be execute at the same time?
  2. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    Yes
  3. chlliew
    Mar 4, 2014
    8
    That simultaneous calls is include internal call, external call and other service provider?
  4. chlliew
    Mar 4, 2014
    8
    for example ,If I make a internal call(Ext XXX) to my colleague (Ext YYY) is 1 simultaneous call or 2 simultaneous call? In the same time my colleague B (Ext ZZZ) make a external call thru our trunk to PSTN ,total is how many simultaneous we use?
  5. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,061
    56
    I believe the logic holds that a single call is defined to be:
    Extension to extension
    Extension to external number
    External number to extension
    Therefore if you make:
    extension to extension to external
    This is considered as two calls - one to the extension and then again from that extension out to an external.
  6. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    "simultaneous call"=conversation.
    Answer to your question is - "two"
  7. chlliew
    Mar 4, 2014
    8
    Thanks for helping
  8. jpillow
    Jun 20, 2011
    1,342
    Sorry, I only really visit the forum on weekends but as ineblett said the answer is yes internal and external calls are both counted as cc's.
