simultaneous calls? how them counted?
Discussion in '3CX Phone System - General' started by hpioteput, Nov 3, 2009.
  1. hpioteput
    Nov 1, 2009
    37
    how simultaneous calls counted?
    per simultaneous calls:
    in the system?
    on the 1 VoIP number?
    on the VoIP providers(all numbers)?
    for example 8 simultaneous calls license.
    Can I use 30 VoIP providers numbers?
    Can I use 30 VoIP providers numbers if all 30 phones calls in 1 time to different extensions? etc...
    Can you fully explain how it work?
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Internal phone to external number = 1 call
    External call to internal number = 1 call
    Extension to extension = 1 call
    Extension to voicemail = 1 call
  3. hpioteput
    Nov 1, 2009
    37
    Thanks KerryG,
    For example:
    I have 30 active connections to VoIP providers(wait for call).
    Would all this connections be included in simultaneous calls?
    Or only Active call to one of the VoIP provider or extension?
  4. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,406
    81
    The Above plus you can have as many extensions as you want, as many providers as you want as long as there is a maximum of 8 calls going on at a time.
  5. hpioteput
    Nov 1, 2009
    37
    All that I need to know.
    LeonidasG and KerryG thank you.
  6. hpioteput
    Nov 1, 2009
    37
    Can't see - "You are not authorised to read this forum."
  7. LeonidasG
    Nov 19, 2008
    1,406
    81
    I am :p
  8. hpioteput
    Nov 1, 2009
    37
    Final question.
    VoIP provider "simultaneous calls" set to 5
    What happens if the sixth incoming calls arrive?
  9. leejor
    10,373
    230
    That could depend on your provider. If 3Cx sends them a message that the call is being rejected then they could provide busy tone or perhaps a recording saying to try your call later. You'd have to try it out. I would think that if you are paying for six simultaneous calls to/from your VoIP provider, then that is the limit you will set in 3CX. Why would you set it for less?
