Simultaneous Calls Issues
Discussion in '3CX Phone System - General' started by Nunzionuk, May 11, 2011.
  1. Nunzionuk
    May 11, 2011
    Hi, we are having an issue with our 8 Simultaneous Calls install. Currently we are only able to have 4 Simultaneous Calls before we get told that we are exceeding the license.
    My question is, does having the PBX Deliver audio checked take up an extra call? As we need this option, but also need to be able to get 8 calls at once.
  2. nbailey
    nbailey Member
    Jan 31, 2011
    359
    PBX delivers audio wouldn't have anything to do with simultaneous calls. Maybe we need to look into what actually consists of a call in this situation.
  3. netswork
    netswork Active Member
    Mar 11, 2011
    577
    I was thinking that 1 extension to extension call was considered 2 calls. So two simultaneous extension to extension calls would tie up 4 licenses.
  4. nbailey
    nbailey Member
    Jan 31, 2011
    359
    no it doesn't work like that. one ext to ext = 1 call, two ext calling two different ext = 2 calls, 1 ext calling voicemail = 1 call, 1 ext calling another ext then holding and transferring to another ext =1 call then 2 calls while 1 is on hold and then 1 again when the transfer is complete. It is the actual call itself that counts as a call and not how many devices are connected.
  5. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    can you go to the 3CX Console, >> Settings >> Activate Licence and see what it says for Product and let us know
  6. netswork
    Mar 11, 2011
    577
    Thanks for clarifying that for me.
  7. nbailey
    nbailey Member
    Jan 31, 2011
    359
    did you check licensing status as Davidbenwell asked? I sort of got off track to your original question.
    I have seen instances when it has reverted back to a free edition from licensed. and free = 4 SC so that
    could be the issue.
