Simultaneous Calls
Discussion in '3CX Phone System - General' started by chrisjr, Jan 30, 2008.
  1. chrisjr
    Jan 23, 2007
    21
    What is exactly meant by simultaneous calls? Does this mean the number of voip accounts that can be added? Does this mean the number of incoming calls or does it mean incoming and outgoing combined?
    Chris.
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    It means total number of all calls on the system at one time.
  3. chriscasas
    Nov 1, 2007
    archie,
    so does that mean if one extension calls the other it makes two simultaneous calls already?
    Chris
  4. archie
    3CX Support
    Aug 18, 2006
    1,299
    No, it is one call.
  5. mr.doquanganh
    Feb 17, 2008
    Usinng 3cx version 3.1, i can have up to 8 simultaneous calls
    How about version 5.1?
    As i see in the Activation menu, the simultaneous calls now unlimited
    Is it right?
    Please reply ASAP
    Thank you
  6. silentfun
    silentfun Member
    Dec 11, 2006
    364
    possible you lost licence information and have to enter again
    Andy
