simultaneous calls ???
Discussion in '3CX Phone System - General' started by admin77, Nov 20, 2015.
  1. admin77
    Nov 20, 2015
    21
    Hi everybody,
    I want to know if my setup will be covered by the free edition (2SC)
    3cx with 1 ISDN BRI line
    3-4 extensions
    no sip trunk
    no bridges
    1-2 Digital receptionists
    1-2 3CX phones on android/iphone
    Do you think i will 've any problems ?
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,956
    179
    it all depends on call volume.
    if a call comes in and gets forwarded to a mobile phone - that is 2 licenses.
    someone else calls in at the same time, 3rd.
    someone starts to check their voicemail via handset, 4th.
    its your knowledge of the call volume that will help you best.
  3. admin77
    Nov 20, 2015
    21
    Hi, I ve configured an iVR which gives the option to call 2 ringing groups
    When some one calls from outside one sc is the ivr and if selects a ringing group it is another sc right ?
    Does it matter that i ve 4 members in the ringing groups ? ot it is still 2 sc
    Where can i see that i ve used all my licences for sc ?
  4. craigreilly
    Feb 1, 2012
    2,956
    179
    A Ring Group uses 1 call license.
    I do not think you can see licenses in use anywhere, although it has been asked for.
