Simultanious Calls?
Discussion in '3CX Phone System - General' started by JVH, Feb 8, 2010.
  1. JVH
    JVH
    Apr 25, 2007
    18
    Trying to decide what version to purchase.
    The 3CXPSPRO Professional Edition 16SC says it will handle 16 simultanious calls.
    Does that mean 16 external calls plus intercom calls or is that internal and external max at 16?
  2. JVH
    JVH
    Apr 25, 2007
    18
    Thanks Matt.
    No problem, just wanted to know so I ordered the right version.
  3. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Simultaneous calls are:
    1. inbound call from external link
    2. the call explicitly initiated by "extension" (live person)
    No exceptions since v7.1
    Please correct me if I'm wrong.
    Incorrect. it is only one call
  4. cfive
    cfive Member
    Aug 20, 2009
    284
    6
    So, does that mean if I have the Small Business 8 call license - and I have 10 extensions - and I do a "page" to a group of all extensions .... the page doesn't succeed?
    - Les.
