Since SP4 update Cant connect to wallboard
Discussion in '3CX Phone System - General' started by stevematthews, Mar 14, 2014.
  1. stevematthews
    Jan 23, 2014
    10
    Anyone know any reasons this will happen since sp4 update??
    It says connecting then. Connection Closed
    Any help
    Steve
  2. carolinainnovative
    May 4, 2009
    369
    6
    I always hate recommending this, but it sometimes fixes issues with IIS-type applications and 3cx...
    Backup ... Uninstall ... Reinstall ... Restore?
    And, stupid question, but have you tried rebooting (hey, lets face it - it's windows)
    Baring that -
    Is the wallboard application showing up in IIS Manager under the default website?
    What version of windows is on the server?
  3. stevematthews
    Jan 23, 2014
    10
    Hi Thanks for your help on this...
    Ive rebooted the vm box (its running server 2012) It runs for about an hour then the numbers disappear off the dash. It still works in the presence information though.
    I have restarted IIS and nothing...
    Reboot of the queue manager within 3cx and it comes back (stats reset though) and again about an hour it will disappear again.
    Steve
