Since the update tot eh 3CX assistant i have the follwoing i
Discussion in '3CX Phone System - General' started by Roshen, Mar 16, 2010.
  1. Roshen
    Jan 16, 2009
    35
    Error opening the log file, log file locked: C:\Users\rsingh\AppData\Roaming\3CX Assistant\Logs\tcx.assistant.client.exe.log Error:The process cannot access the file 'C:\Users\rsingh\AppData\Roaming\3CX Assistant\Logs\tcx.assistant.client.exe.log' because it is being used by another process.
    How do i resolve this?
    The assistant client seems to hang when this occure, then eventually resums opperation as per normal.
  2. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Hi, find this file, C:\Users\rsingh\AppData\Roaming\3CX Assistant\Logs\tcx.assistant.client.exe.log
    Locate it on the drive, close assistant delete it and start assistant again.
    See if this resolves the problem.
    Also confirm that you do not have multiple assistants running on the same machine.
  3. Roshen
    Jan 16, 2009
    35
    cheers Micheal.
    I have done this and will keep an eye.
    thanks.
  4. Roshen
    Jan 16, 2009
    35
    Update:
    I'm unsure if the error logged is related to this issue,
    I have tried Micheals suggestions below, the errors are still being logged.
    "Also confirm that you do not have multiple assistants running on the same machine"
    How to check this?
    I have checked under msconfig, and disabled all 3cx apps
    To recap the issue:
    I have upgraded the clients to:
    Installed Version 8.0.11114.0
    Executable Version 8.0.0.11110
    Since then users reported the following:
    The client seems to crash (not responding)
    The client takes long to log in or respond
    The client constantly switches between "connected" and "logging in"
    This means
    they cannot log in / out of queues
    they cannot transfer calls
    Further, when the client appears to hang, calls are dropped - this is likely that the user is pressing buttons, but getting no response, and the useraction ends that call, or the call is transfered but the 3xc assistant does not reflect this.
    I know there are other ways to log in and transfer ect, but the point of the assistant is to do this / make this easier.
