Singapore Dial Tones
Discussion in '3CX Phone System - General' started by AndyBarr, Jan 25, 2017.
  1. AndyBarr
    Apr 8, 2015
    33
    HI all,
    Just about to setup a 3CX system in Singapore and we are trying to connect the 3CX System via their ISDN line using a Patton SN4120 gateway.
    Does anyone know what dial tone Singapore uses so I can set the gateway up.
    thank
    Andy
  2. GiannosC_3CX
    GiannosC_3CX Guest
    Dear Andy,
    It is better to contact your VOIP Gateway manufacturer for further help on configuring your gateway with the correct Call Progress Tone settings for your country. Also on this link you can find a database of Call Progress Tones for all Countries.
  3. AndyBarr
    Apr 8, 2015
    33
    Thanks for this, I will get in touch with them.
