single DID fax to extension
Discussion in '3CX Phone System - General' started by smokeman, Nov 21, 2011.
  1. smokeman
    Dec 10, 2010
    50
    I've been all through the interface, and can't seem to find a way to make it possible to fax to an extensions email address, without using separate DID's per user. Would it be possible to use the voice application designer to do this, or am I missing something?
    I'd like to have a call attendant answer the incoming fax DID, and if an extension is dialed, start fax to that extensions email, if not, have it go to a default mailbox(which goes to our secretaries).
    Thanks,
    Barry Smoke
  2. smokeman
    Dec 10, 2010
    50
    anyone...?
  3. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    You need separate DID. No way to recognize fax automatically.
