Single digit number dialed form extension - redirect to IVR, is it possible?
Discussion in '3CX Phone System - General' started by Dalibor, Jan 31, 2018.
  1. Dalibor
    Jul 18, 2017
    7
    I'd like to create an extension that would have a dial plan like this: { xS0 }, so when a single number is pressed it is connected to a pre-defined extension, or an IVR.
    Is it possible with 3CX ?
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,094
    165
    Within the extension you can enter a SIP ID - Extensions -> Options - SIP ID - this can be anything. Most common reason is to add operator number 0 to an extension
    On a phone, you dial the SIP ID
  3. Dalibor
    Jul 18, 2017
    7
    Thank you! That works well!
