Single voicemail for multiple extensions
Discussion in '3CX Phone System - General' started by safemode, Mar 19, 2014.
  1. safemode
    Jan 17, 2010
    28
    14
    we are in a situation where a client wants all users with desk IP phones to share a single voicemail box, which is easy in the 3CX management console, the issue is we need the MWI on the desk phones to work on all the phones, can this be achieved with 3CX system Pro v12, and if it can, how do we go about it.
    many thanks
  2. 12494
    12494 Member
    Apr 16, 2010
    306
    31
    You should be able to do this by just assigning the same extension number to each of these phones.
    In v12 you can have multiple phones provisioned to the same extension.
    Regards,
    Allen
