SIP ALG Fails without any firewall
Discussion in '3CX Phone System - General' started by Michael Moore, Dec 19, 2017.
  1. Michael Moore
    Aug 2, 2017
    8
    The primary interface of our 3CX is connected directly to our comcast internet connection with a static IP. We're not using any firewall on that interface. Everything on the firewall check succeeds except:
    testing 3CX SIP Server... failed (How to resolve?)
    • stopping service... done
    • detecting SIP ALG... failed (How to resolve?)
    • testing port 5060... done
    • starting service... done
    Any ideas as to how to resolve? We don't have any devices in between the 3CX and the ISP's router.​
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    64
    You may need to inform Comcast that the modem needs to have its SIP ALG disabled. Many cable modems have such ALGs embedded as some customers do not have their own router and the modem acts as one to include the firewall.
    YiannisH_3CX likes this.
  3. Michael Moore
    Aug 2, 2017
    8
    Thanks. That's the most obvious answer so you're probably right. I'll open a ticket with Comcast and see if they can check the cable modem's config.
