SIP Broker incoming call rejected
Discussion in '3CX Phone System - General' started by alamperti, Apr 1, 2008.
  1. alamperti
    Mar 31, 2008
    Hi All: I'm running 3CX server free v5.1.4128
    The server is configured and working fine, DNS SRV records listed for domain and option "Direct SIP calls" enabled.
    Incoming connections from the Internet are OK when dialed directly to my extension (eg: 742@mollificiovalli.it or 742@sip.mollificiovalli.it)
    08:24:36.323 Call::Terminate [CM503008]: Call(2): Call is terminated
    08:24:29.745 CallLeg::eek:nConfirmed Session 19 of leg C:2.1 is confirmed
    08:24:29.479 CallCtrl::eek:nLegConnected [CM503007]: Call(2): Device joined: sip:742@192.168.2.61:5060;rinstance=5997bbae88746388
    08:24:29.464 CallCtrl::eek:nLegConnected [CM503007]: Call(2): Device joined: sip:280869@eu.voxalot.com
    08:24:29.464 MediaServerReporting::SetRemoteParty [MS210003] C:2.1:Answer provided. Connection(transcoding mode):85.34.159.98:9002(9003)
    08:24:29.448 MediaServerReporting::SetRemoteParty [MS210001] C:2.2:Answer received. RTP connection: 192.168.2.61:8000(8001)
    08:24:29.448 CallLeg::setRemoteSdp Remote SDP is set for legC:2.2
    08:24:27.682 Extension::printEndpointInfo [CM505001]: Ext.742: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Zoiper for Windows rev.650] Transport: [sip:192.168.2.9:5060]
    08:24:27.682 CallCtrl::eek:nAnsweredCall [CM503002]: Call(2): Alerting sip:742@192.168.2.61:5060;rinstance=5997bbae88746388
    08:24:27.573 MediaServerReporting::SetRemoteParty [MS210002] C:2.2:Offer provided. Connection(transcoding mode): 192.168.2.9:7056(7057)
    08:24:27.557 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(2): Calling: Ext:742@[Dev:sip:742@192.168.2.61:5060;rinstance=5997bbae88746388]
    08:24:27.557 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to [sip:742@sip.mollificiovalli.it]
    08:24:27.557 MediaServerReporting::SetRemoteParty [MS210000] C:2.1:Offer received. RTP connection: 89.186.92.107:55528(55529)
    08:24:27.557 CallLeg::setRemoteSdp Remote SDP is set for legC:2.1
    08:24:27.557 Extension::printEndpointInfo [CM505001]: Ext.280869: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] Transport: [sip:192.168.2.9:5060]
    08:24:27.511 CallCtrl::eek:nIncomingCall [CM503001]: Call(2): Incoming call from Sip.280869 to [sip:742@sip.mollificiovalli.it]
    08:24:27.261 CallLeg::eek:nNewCall [CM500002]: Info on incoming INVITE:
    INVITE sip:742@sip.mollificiovalli.it SIP/2.0
    Via: SIP/2.0/UDP 85.17.19.194;branch=z9hG4bKc00d.cece5344.0
    Via: SIP/2.0/UDP 89.186.92.107:53514;iid=2;branch=z9hG4bK024d4c7d37fb181086ccbe498d3c0acd;rport=53514
    Max-Forwards: 69
    Record-Route: [sip:85.17.19.194;lr=on;ftag=8e464b7d37fb181086ccbe498d3c0acd]
    Contact: [sip:280869@89.186.92.107:53514]
    To: [sip:742@sip.mollificiovalli.it]
    From: [sip:280869@eu.voxalot.com];tag=8e464b7d37fb181086ccbe498d3c0acd
    Call-ID: b8a0477d-37fb-1810-84ba-be498d3c0acd
    CSeq: 4712 INVITE
    User-Agent: fring
    Content-Length: 0
    P-hint: outbound
    I've listed our SIP server into the SIP Broker peering directory, and received *9052 as a network code.
    When I try to dial the same extension, from the same softphone as in previous logged example, the
    caller is reported as unknown and the incoming call aborts.
    08:28:54.393 Call::Terminate [CM503008]: Call(3): Call is terminated
    08:28:54.377 CallCtrl::eek:nIncomingCall [CM502001]: Source info: From: 3; To: [sip:280869@eu.voxalot.com];tag=0093e87e37fb181093abd9ba379bad33[sip:*9052742@eu.voxalot.com]
    08:28:54.377 CallCtrl::eek:nIncomingCall [CM503012]: Call(3): Incoming call rejected, caller is unknown; msg=SipReq: INVITE 742@sip.mollificiovalli.it tid=6ee1.22119fe.0 cseq=INVITE contact=280869@89.186.92.109:53545 / 4712 from(wire)
    08:28:54.361 CallLeg::eek:nNewCall [CM500002]: Info on incoming INVITE:
    Via: SIP/2.0/UDP 64.34.162.221;branch=z9hG4bK6ee1.22119fe.0
    Via: SIP/2.0/UDP 85.17.19.194;branch=z9hG4bK6ee1.751dc287.0
    Via: SIP/2.0/UDP 77.93.254.231:53545;iid=2;branch=z9hG4bK5007ea7e37fb181093abd9ba379bad33;rport=53545
    Max-Forwards: 68
    Record-Route: [sip:64.34.162.221;lr=on;ftag=0093e87e37fb181093abd9ba379bad33]
    Record-Route: [sip:85.17.19.194;lr=on;ftag=0093e87e37fb181093abd9ba379bad33]
    Contact: [sip:280869@89.186.92.109:53545]
    To: [sip:*9052742@eu.voxalot.com]
    From: [sip:280869@eu.voxalot.com];tag=0093e87e37fb181093abd9ba379bad33
    Call-ID: 8c8ce77e-37fb-1810-80c5-d9ba379bad33
    CSeq: 4712 INVITE
    User-Agent: fring
    Content-Length: 0
    P-hint: outbound
    P-src-ip: 77.93.254.231
    I've searched both the forum and the support area but all info refers to incoming calls through a
    provider and not directly ... maybe it's too tricky for me to get through. Any help would be greatly
    appreciated :)
    Regards, Alex
    Update
    Provisional workaround found.
    Created a VoIP provider "SIP Broker", without registration.
    Added this matching strategy in Source Identification
    SIP Field (To: User Part) - Value (Custom Field) - Custom Value (*9052742)
    Now incoming calls via the SIP Broker alias are flowing smoothly.
    There's only an issue, that matching strategy covers only extension 742..
    Is there a way to create a matching pattern like *9052any_other_number ?
