SIP Calls via 3CX-VoIP client
Discussion in 'Windows' started by arpa, Apr 28, 2008.
  1. arpa
    Feb 14, 2008
    35
    I am not able to make SIP Calls using the 3CX's client, even if this option is enabled from the server. Is this feature designed for future release ... ?
