SIP client for mobiles / Wireless SIP phone
Discussion in '3CX Phone System - General' started by Pentangle, Dec 18, 2007.
  1. Pentangle
    Pentangle Member
    Dec 6, 2007
    261
    Hi all,
    This is a 2-part question:
    1) I'm using an i-mate SP5 for mobile calls - does anyone here use a SIP client for WM5 or WM6 phones? and if so, what do you think of it?
    2) Is anyone using a wireless SIP handset? and if so, which model and what do you think of it?
    Cheers,
    Mike.
  2. juliogiraldo
    Dec 17, 2007
    For WM5 xlite had a smart software beta to this devices. Works fine but the headset was the external from the phone.
    In WM6, I use the own WM voIP feature. Works fine and is 100% functional.
    Julio
  3. AldoLinares
    AldoLinares New Member
    Nov 12, 2007
    135
    I have the Tmobile Dash that have WM6 Smartphone edition, but what default WM Voip feature are talking about?
    Thank you
  4. AldoLinares
    Nov 12, 2007
    135
    I found http://www.fring.com and its working, not perfect but its working on my phone via wifi.
    :D
  5. alicic
    alicic New Member
    Oct 3, 2007
    119
    I have used this SIP software on WM
    speaQ SIP softphone for Mobile Phones
    Works just fine,
  6. alicic
    alicic New Member
    Oct 3, 2007
    119
    Tested also,
    http://www.ageet.com/us/download.htm
    regards,
  7. juliogiraldo
    Dec 17, 2007
    In some WM6 smartphones, the features is not installed by default.
    You must follow the next steps: http://wiki.xda-developers.com/index.php?pagename=HTC_Vox
    It runs OK in all WM6 Smaartphone.
    Julio
  8. Pentangle
    Pentangle Member
    Dec 6, 2007
    261
    Thanks guys.
    I had already downloaded Fring last night, but it wouldn't register against my 3CX. Was there a technique i'm missing?
    Cheers,
    Mike.
  9. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,991
    304
    I cant directly answer your question, but i can tell you that this is an area we wish to really support/focus on.
    We are getting our hands on a Windows Mobile 6 phone as well as Nokia with SIP client. We are planning full interoperability testing and are interested to hear about experiences of others and any problems you might have.
  10. AldoLinares
    Nov 12, 2007
    135
    I configured my T-Mobile Dash with fring.com, then just add it the info of the 3CX server and just work i was a little amazed how easly it was and how good it work.
    I was showing it to a client and just that sell the software for itself, its a very nice feature because now on a hotspot i can make free local calls or international calls (not free but almost) and recibe calls that are made to my office to my phone.
    As i say its not perfect because depends on wifi and internet.
  11. Pentangle
    Pentangle Member
    Dec 6, 2007
    261
    Nick, we already have a bunch of WM5 and WM6 phones in our client-base since another of our services sold to the customer is hosted MS Exchange services and DirectPush to mobiles.
    Let me know if/when you have a beta planned for this, as I would definitely be interested.
    Currently Fring looks good as it integrates well into the WM5 phone book etc, and I can make the test call to Fring correctly, but the client just refuses to connect to either of my 3CX deployments :(
    I think what we're crying out for is a SIP client (both desktop and mobile) which takes into account that we'd want to deploy technology like this to idiots instead of techies :) i.e. the less abstract functions and obscure registration procedures the better!
  12. AldoLinares
    Nov 12, 2007
    135
    Pentangle
    Do you have correctly configure firewall, because my phone its working fine with fring, i can make calls and get calls, i just added my extension info into the sip account thats is.
    Its working fine.
  13. Pentangle
    Pentangle Member
    Dec 6, 2007
    261
    Yes, and I was also trying it inside the LAN with our wifi and it wouldn't work there either.
    What are you using to register? your extension number @ your 3cx implementation ip address or domain name? or something else?
    Are you also filling in the proxy address at all?
  14. simones181170
    Dec 4, 2007
    51
    fring works well olso with nokia E65
    it's very simply to configure
    User: (number of EXT)
    pass: (pass of EXT)
    gateway: (public ip of the Server 3cx) with the domain name won't work
    if don't work there are problem in Nat ore Firewall configuration
  15. Wardy
    Wardy New Member
    Sep 18, 2007
    110
    I used a Nokia N95 (UK on orange, so no true support for SIP) with fring on V3 and it work fine, not tried it on V5 yet though
  16. Wardy
    Wardy New Member
    Sep 18, 2007
    110
    Does anyone know of software that will allow SIP on a Blackberry 8820, 8100 or 8320?
  17. Pentangle
    Pentangle Member
    Dec 6, 2007
    261
    I finally got it working with my setup today.
    Basically, it looks like the SIP client expects STUN or at least to be able to resolve the external IP of the 3CX server, and won't work on an internal IP (which is a bit weird). I wonder whether it tries to do it's registration via GPRS though, despite me having wifi enabled and calls going through that.
    Ah well, it works now, and the main reason was actually that the new release of v5 seems to work MUCH better than the old one.
  18. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    hello
    Could you please post your mobile configuration?
    i am trying to use a blackberry like a remote extension
    best regards
  19. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    i didnt mentioned the model is a blackberry 8100
  20. Pentangle
    Pentangle Member
    Dec 6, 2007
    261
    Just to be clear, my post quoted above referred to using Fring on a WM5 smartphone.
