SIP Conference Phone
Discussion in '3CX Phone System - General' started by iamgreen, Mar 20, 2013.
  1. iamgreen
    Sep 25, 2007
    52
    Hello there! I am looking for a conference phone that will work with the 3CX v11 platform. In the past I have used analog polycom phones with with an ATA bit I want to go native SIP.
    I purchased a Panasonic conferencing phone that they SWORE was a SIP complaint phone, but once I received it, I was apparent that it was designed for their KX series of PBX's and the SIP compatibility was an afterthought.
    Is there a SIP conferencing phone that is a sure fire match to 3CX?
    Thanks!
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,083
    61
    I will be trying a clear one max-ip tomorrow . Will let you know.
  3. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    I've used only the Polycom SoundStation ip 6000-70000 both worked with no problems, superior call quailty.
  4. Cynthia Slade
    Mar 22, 2012
    45
    We have used several Polycom Soundstations (6000 & 7000) and have had no problems.
  5. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    @lneblett, I posted a configuration guide for the Max Attach IP in here a bit over a year ago, the sound was barely OK. We have one in a small meeting room in our office.
    The Polycom IP7000 is a good phone, we use it in our main conference room but I must say that it is a bit on the high side $$$.
    Konftel makes a good phone at a reasonable price.
  6. lneblett
    Sep 7, 2010
    2,083
    61
    Charles -
    Thanks, the install was about as easy as it gets.
    Volume for room size was fine, but I did testing with cell phone, so not sure how well mic pick up is for volume at remote side. I offered Polycom as well, but $$ got in the way of start-up attorney's office. Have not tried Konftel, but I think I have another client who is about to pull the trigger, so maybe then.
  7. iamgreen
    Sep 25, 2007
    52
    The Konftel looks cool. What model works with 3cx? Can it be provisioned?
  8. iamgreen
    Sep 25, 2007
    52
  9. iamgreen
    Sep 25, 2007
    52
  10. cobaltit
    cobaltit Active Member
    Mar 22, 2012
    913
    146
    *ANY* SIP phone should be work with 3CX, and *ANY* phone can be provisioned if you make your own template. But the Konftel is not an officially supported phone nor does 3CX come with a provisioning template for it. So you would configure the Konftel manually with the SIP account information.
