sip diversion header
Discussion in '3CX Phone System - General' started by gbra, Mar 19, 2015.
  1. gbra
    Mar 19, 2015
    We are using 3CX phone system 12 SP6. I need to be able to send the diversion header in the sip invite. I've been reading that this should be possible if you specify it in the forwarding rules of the extension. However, this was always with previous versions. I cannot find this option in version 12. Also I do not see it in the outbound parameters of the VOIP provider options.
    Where can I enable this?
    Kind regards,
    Guy
  2. nikosT_3cx
    3CX Support
    Jun 2, 2014
    57
    setup a DID to route the call directly to the extension you want ( not through an IVR, Ring Group or Queue ) and then go onthe Forwarding Rules of the extension.
    On the Away/Out of Office status >> Forward external calls to>> An external number or Skype ID, and after you select this option you will see the option 302 Diversion Header to be activated.
