SIP Error 480 Temporarily Unavailable
Discussion in '3CX Phone System - General' started by countrycomp, Mar 24, 2017.
  1. countrycomp
    Dec 2, 2008
    53
    I have a v15 SP5 64SC with a 10 channel sip trunk. Everything appears to be working properly except when an external call comes in via the sip trunk, is answered at a reception extension and an attended transfer is started to the desired extension. If the called party does not answer it is set to forward to their mobile. This progresses properly and the call can be answered on the mobile phone and converse with recepetion OK but when the transfer tries to complete then the call fails with an error 480 Temporarily Unavailable message. Blow is an except from the trace done by our sip trunk provider (with identifying digits replaced).
    INVITE sip:04xxx6789@XXX.XXX.XXX.38:5060 SIP/2.0
    Via: SIP/2.0/UDP XXX.XXX.XXX.97:5060;branch=z9hG4bK-524287-1---
    1f7be46505433776;rport
    Max-Forwards: 70
    Contact:
    :612xxxx1250@XXX.XXX.XXX.97:5060>
    To:
    :04xxxx789@XXX.XXX.XXX.38:5060>
    :612xxxx1250@XXX.XXX.XXX.38:5060>;tag=3f476535
    Call-ID: 3W2WdsvYbZ8fUwyD5FCsew..
    CSeq: 1 INVITE
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER,
    INFO, MESSAGE
    Supported: replaces
    User-Agent: 3CXPhoneSystem 15.0.62928.5 (62293)
    Replaces: q29PgDu3f7tCSCKxCqI5gg..;to-tag=7vK2BgvU22D7S;from-tag=0640c502
    P-Preferred-Identity:
    :6123xxxx250@XXX.XXX.XXX.38:5060>
    Remote-Party-ID: "6123xxxx250"
    :6123xxxx250@XXX.XXX.XXX.38:5060>;party=calling
    Content-Length: 0
    SIP/2.0 480 Temporarily Unavailable
    9a4d0b17e47a392c;rport=5060
    Max-Forwards: 70
    :61xxxx1250@XXX.XXX.XXX.38:5060>;tag=3f476535
    To:
    :0xxxx6789@XXX.XXX.XXX.38:5060>;tag=NUNX4a8ctZ5cc
    CSeq: 2 INVITE
    User-Agent: SBC-Summit
    Accept: application/sdp
    Allow: INVITE, ACK, BYE, CANCEL, OPTIONS, MESSAGE, INFO, UPDATE, REGISTER,
    REFER, NOTIFY
    Supported: timer, path, replaces
    Allow-Events: talk, hold, conference, refer
    Reason: Q.850;cause=96;text="MANDATORY_IE_MISSING"
    Content-Length: 0
    P-Asserted-Identity: "61xxxx6789"
    Dave P.
    #1 countrycomp, Mar 24, 2017
  2. GiannosC_3CX
    GiannosC_3CX Guest
    Hi countrycomp,
    Please check your inbox, I have sent you a p.m
