SIP for Skype Beta - configuration instructions
Discussion in '3CX Phone System - General' started by robpemberton, Mar 18, 2010.
  1. robpemberton
    Jan 6, 2010
    11
    Has anyone been able to get the SIP for Skyp Beta working? Are there instructions available for setting up this as a voip provider?
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
  3. robpemberton
    Jan 6, 2010
    11
    Thanks for the reply -
    Thats' great info for setting up the 3cx gateway to skype.
    I'm looking to configure - Sip to Skype
    Is there documentation on that?
  4. leejor
    11,128
    330
    If it is still a Beta then I would assume that they aren't releasing any of the needed info (server name, etc) to the general public just yet. If you have signed up with them then you would probably be given the standard information that you would need as with any SIP provider. That could then be "plugged into" the generic SIP trunk setup. Perhaps someone on the board is using Skype (the SIP version) and can fill us in?
  5. robpemberton
    Jan 6, 2010
    11
    Here is the guide from skype -
    http://download.skype.com/share/business/guides/skype-for-sip-quick-start-guide.pdf
    I have used the generic provider to try to set this up and it isn't working.
    Anyone have any ideas of what to try?
  6. fceledon
    Apr 19, 2010
    6
    Any news about this? I cant' make it work.... (sip.xx.com is my server)
    The registration is OK
    11:32:53.915 [CM503020]: Normal call termination. Reason: Not found
    11:32:53.915 [CM503016]: Call(37): Attempt to reach <sip:90115625551212@sip.xx.com> failed. Reason: Not Found
    11:32:53.905 [CM503003]: Call(37): Call to sip:0115625551212@sip.skype.com:5060 has failed; Cause: 404 Not Found; from IP:63.209.144.201:5060
    11:32:52.763 [CM503025]: Call(37): Calling VoIPline:0115625551212@(Ln.10001@skype)@[Dev:sip:99051000003718@198.172.147.196:5060;rinstance=dfcd15b3f45597bb]
    11:32:52.453 [CM503004]: Call(37): Route 1: VoIPline:0115625551212@(Ln.10001@skype)@[Dev:sip:99051000003718@198.172.147.196:5060;rinstance=dfcd15b3f45597bb]
    11:32:52.382 [CM503010]: Making route(s) to <sip:90115625551212@sip.xx.com>
    11:32:52.312 [CM505001]: Ext.110: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Sipura/SPA941-4.1.8] PBX contact: [sip:110@192.168.0.174:5060]
    11:32:52.162 [CM503001]: Call(37): Incoming call from Ext.110 to <sip:90115625551212@sip.xx.com>
  7. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Selected log message provides information for you.
    You can ask your provider about how to correctly form a dialed number to be able to reach the destination.
  8. fceledon
    Apr 19, 2010
    6
    Thanks, indeed the solution was pretty simple:
    On the skype sip rule, if the number starts with "011" remove 3 and prepend a "+" sign.
    .... now working fine!!
