Sip Forking
Discussion in '3CX Phone System - General' started by Archie Frederic, Jan 31, 2017.
  1. Archie Frederic
    Jan 31, 2017
    69
    Have you ever wondered of the limitation of SIP Forking? a single extension can have multiple phones registered, but is there a limit on how much phone can be registered on a single extension?
  2. daktur
    daktur New Member
    Oct 15, 2015
    225
    6
    Hey Archie,
    You should consider that even if you register 100 phones in a single extension, once this extension is on a call all the phones should act as configured rules and if the option to get more than 1 call at a time is not enable it is kind of useless to do so. More than that the system have enough functions to avoid this kind of situation since it's limited by the simultaneous calls and not by extensions , trunk or anything else.
  3. leejor
    10,360
    226
    The limitation I see, if you tried to SIP Fork an outrageous number of extensions, is the ability to send out all of the SIP messages, for an incoming call, in a timely manner. At some point, the call may be answered before the last extension even begins to ring. For most situations, there isn't going to be a problem.
    Archie Frederic likes this.
