SIP INFO DTMF Digits '*' and '#' are not sent correctly
Discussion in 'Windows' started by summitraj, Feb 5, 2010.
  1. summitraj
    Feb 5, 2010
    I am using SIP INFO for DTMF digits using 3CX Phone ver. 4.0.10373.0
    The digits '*' is sent as Signal=10 and '#' is sent as Signal=11
    Is it a standard way to send the value of DTMF digits. Other SIP Phones send them as DTMF characters as follows
    Signal=#
    Signal=*
    Looks like a bug.
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    What is specified in content-type header?
    What are the "Other SIP Phones"?
  3. sebastiao.salviano
    Mar 1, 2010
    Hello !!!
    I've the same situacion with the my server, in the tranfer for the my server the digits are sent with 10 when i used the *. For the correctly transfer the 3CX need to send * for my server. Is there some thing modify the send of digit * ?
  4. SY
    3CX Support
    Jan 26, 2007
    1,825
    What is the server you are using?
  5. rick_it_2004
    Apr 4, 2009
    5
    SIP INFO isn't a standard, each telephony server is free to implement SIP INFO support for DTMF in their own way. The only "standard" is RFC 4730, using KPML as a event package. This is supported by Cisco but not by many other vendors as they don't like Cisco ideas generally.
  6. summitraj
    Feb 5, 2010
    Content-Type: application/dtmf-relay
  7. odf
    odf
    Jul 3, 2008
    9
    I do not understand, please can tell me what part I need to check this, on the phone or on the 3CX?
  8. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,455
    92
    You would have to configure this correctly on the phone.
