SIP Invite - Outbound
Discussion in '3CX Phone System - General' started by David1921, Feb 5, 2018.
  1. David1921
    Feb 5, 2018
    6
    Hello
    We are trying to set up a generic SIP provider, the Provider requires that the SIP outbound invite must have the from address as our 3cx server in order to do authentication. Currently the from address being sent is our outbound proxy address
    Is there anyway to change the from address manually to a specific IP?
  2. mariosM_3CX
    mariosM_3CX Support Team
    Nov 1, 2017
    401
    36
    Hello @David1921
    Cannot guarantee that this will work, as we are not talking about a supported provider, but try changing the From : Host Part to "ContactUri" in the SIP trunk's Outbound Parameters.
    Hope this helps.
  3. David1921
    Feb 5, 2018
    6
    Thanks MarioM_3CX
    I have tried this but it looks like it doesn't make a difference.
    The invite still sends the outbound proxy address instead, so I am out of ideas.
    The provider is Verizon so we can't actually ask them to authenticate on another parameter.
  4. mariosM_3CX
    Nov 1, 2017
    401
    36
    If you try setting the From : Host Part to "Custom Field " and manually write the public ip of the PBX, is it working?
  5. David1921
    Feb 5, 2018
    6
    No, it still sends the outbound proxy IP.
  6. IoannisM_3CX
    IoannisM_3CX Support Team
    Aug 10, 2017
    228
    17
    Hello @David1921
    as this will need some further investigation, can you please pm us a capture and your logs in verbose mode in order to see what exactly leaves from the PBX to your provider?
    Set the From : Host Part to "Custom Field " and manually write the public ip of the PBX as my colleague suggested and replicate the issue
  7. David1921
    Feb 5, 2018
    6
    @ loannisM_3cx PM sent
  8. simply7
    Jan 4, 2016
    38
    16
    Restart the services after the change.
