SIP OPTION message
Discussion in '3CX Phone System - General' started by gregor, Aug 28, 2007.
  1. gregor
    Aug 28, 2007
    We have problems with our voip provider. Calls are hunged up after 20 sec. Provider told me that they maintain registration with keepalive OPTION message and we have to activate SIP OPTION message. Where to check this?
    Here is log from them:
    Registration and call establishment are OK.
    One on call, we send, like for all devices, a keepalive "OPTION" message.
    client answers with a 5xx error message (not implemented). This causes us to unregister it, and send a bye.
    Here are the logs about that event :
    2007/08/01-15:47:56.635 [DEVICE_HANDLER xxxxxxxxe (sip-phone) – (null) –
    $Map,java.util.Collections$SynchronizedMap($S,601012;com.netergynet.protocolhandler.sip.Handler,$S,[PHA] [HSIP: [601012] / 601012-master-1] )] unreachable()
    2007/08/01-15:47:56.635 [PHA] [HSIP: [601012] / 601012-master-1] unreachable(sip:601012-master-1@212.13.228.50:5061)
    2007/08/01-15:47:56.635 [PHA] [HSIP: [601012] / 601012-master-1] disconnect([[PHA] [RTPSId]
    Unknown macro: {601012-->41756485}
    states= mode:ACTIVE, targetMode:ACTIVE inService:OUT_OF_SERVICEuri:601012.stranke] , CAUSE_NORMAL)
    2007/08/01-15:47:56.636 ===== Sent ======================= 03:47:56 635
    lewis/212.13.228.50:5061 ===UDP===> /212.13.228.50:5060
    BYE sip:xxxxxxxxxx@xxxxxxxxx:5060;raddr=xxxxxxx;rport=5060;natted=true SIP/2.0
    This is the same reason why on incoming call, it fails.
    The NCH is unregistered after a failed keepalive, and incoming calls are transfered to voicemail or fail.
    You may check if that PBX supports standard OPTION SIP messages, and if , activate their support in configuration.
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    We do not support OPTIONS at all.
    What is the provider, by the way?
