SIP packets dropped ?
Discussion in '3CX Phone System - General' started by michaelbird75, Jun 19, 2015.
  1. michaelbird75
    Nov 30, 2014
    I have a 3CX connected via private LAN to a SIP server. Inbound calls work. Outbound calls are not working right now.
    Outbound call from 3CX to cell captured on wireshark from local interface of 3CX server:
    T38 sends invite to3CX
    3CX sends invite to SIP
    SIP sends 100 trying
    3CX sends another invite to SIP
    Sip sends a 183 progress
    3CX sends invite
    SIP begins RTP stream
    3CX sends invite
    When i check the 3CX server interface I see the SIP requests timing out as if no packets have been received from the SIP server.
    Any thoughts?
    Verbose below:
    Wireshark:
    |Time | 172.18.132.1 | 10.16.0.245 |
    | | | 10.16.0.246 |
    |41.901752000| INVITE SDP (g711U g7 | |SIP From: "14444356475"<sip:14444356475@172.18.132.1:5060 To:<sip:2534677@10.16.0.246:5060
    | |(5060) ------------------> (5060) | |
    |41.904791000| 100 Trying| | |SIP Status
    | |(15706) <------------------ (5060) | |
    |42.401850000| INVITE SDP (g711U g7 | |SIP From: "14444356475"<sip:14444356475@172.18.132.1:5060 To:<sip:2534677@10.16.0.246:5060
    |42.404417000| 100 Trying| | |SIP Status
    |43.401841000| INVITE SDP (g711U g7 | |SIP From: "14444356475"<sip:14444356475@172.18.132.1:5060 To:<sip:2534677@10.16.0.246:5060
    |43.404126000| 100 Trying| | |SIP Status
    |45.476999000| INVITE SDP (g711U g7 | |SIP From: "14444356475"<sip:14444356475@172.18.132.1:5060 To:<sip:2534677@10.16.0.246:5060
    |45.478860000| 100 Trying| | |SIP Status
    |47.785779000| 183 Session Progress | |SIP Status
    |47.909154000| RTP (g711U) | |RTP Num packets:1056 Duration:21.117s SSRC:0x12D86402
    | |(7010) <-------------------------------------- (20224) |
    |49.477017000| INVITE SDP (g711U g7 | |SIP From: "14444356475"<sip:14444356475@172.18.132.1:5060 To:<sip:2534677@10.16.0.246:5060
    |49.479641000| 183 Session Progress | |SIP Status
    |52.788045000| 200 OK SDP (g711U te | |SIP Status
    |53.285824000| 200 OK SDP (g711U te | |SIP Status
    |54.285856000| 200 OK SDP (g711U te | |SIP Status
    |56.285464000| 200 OK SDP (g711U te | |SIP Status
    |57.506147000| INVITE SDP (g711U g7 | |SIP From: "14444356475"<sip:14444356475@172.18.132.1:5060 To:<sip:2534677@10.16.0.246:5060
    |57.508430000| 200 OK SDP (g711U te | |SIP Status
    |60.284928000| 200 OK SDP (g711U te | |SIP Status
    |64.285343000| 200 OK SDP (g711U te | |SIP Status
    |68.284643000| 200 OK SDP (g711U te | |SIP Status
    |72.284873000| BYE | | |SIP Request
    | |(5060) <------------------ (15725) | |
    |72.385245000| 481 Call/Transaction | |SIP Status
    |73.521309000| INVITE SDP (g711U g7 | |SIP From: "14444356475"<sip:14444356475@172.18.132.1:5060 To:<sip:2534677@10.16.0.246:5060
    |73.524065000| 200 OK SDP (g711U te | |SIP Status
    3Cx side:
    19-Jun-2015 16:44:45.412 L:4.1[Extn]: Terminating targets, reason:
    19-Jun-2015 16:44:45.412 Leg L:4.1[Extn] is terminated: Cause: BYE from PBX
    19-Jun-2015 16:44:45.412 Terminated from "Jacklyn"<sip:6700@172.18.132.1>;tag=1601723566 to <sip:92354455@172.18.132.1>;tag=8420fb4f; reason: Rejected
    19-Jun-2015 16:44:45.412 L:4.1[Extn] Sending: OnSendResp Send 480/INVITE from 0.0.0.0:0 tid=1924022360 Call-ID=4240812910@172.18.132.13:
    SIP/2.0 480 Temporarily Unavailable
    Via: SIP/2.0/UDP 172.18.132.13:5062;branch=z9hG4bK1924022360
    To: <sip:92354455@172.18.132.1>;tag=8420fb4f
    From: "Jacklyn"<sip:6700@172.18.132.1>;tag=1601723566
    Call-ID: 4240812910@172.18.132.13
    CSeq: 2 INVITE
    Warning: 499 3CX-PC "No answer"
    Content-Length: 0
    19-Jun-2015 16:44:45.412 SendMsg from <sip:92354455@172.18.132.1>;tag=8420fb4f to "Jacklyn"<sip:6700@172.18.132.1>;tag=1601723566
    19-Jun-2015 16:44:45.362 ~Target=VoIPline:2354455@(Ln.10000@wtf)
    19-Jun-2015 16:44:45.362 Call(C:4) is terminated
    19-Jun-2015 16:44:45.362 [CM503020]: Call(C:4): Normal call termination. Call originator: Extn:6700. Reason: No answer
    19-Jun-2015 16:44:45.362 [CM503016]: Call(C:4): Attempt to reach <sip:92354455@172.18.132.1:5060> from Extn:6700 has failed. Reason: No Answer
    19-Jun-2015 16:44:45.361 L:4.2[Line:10000>>2354455]: Terminating targets, reason: SIP ;cause=408 ;text="Request Timeout"
    19-Jun-2015 16:44:45.360 [Flow] Current call diversion path:[]
    19-Jun-2015 16:44:36.216 Currently active calls - 1: [4]
    19-Jun-2015 16:44:13.250 [CM503025]: Call(C:4): Calling T:Line:10000>>2354455@[Dev:sip:14425546457@10.16.0.246:5060] for L:4.1[Extn]
    19-Jun-2015 16:44:13.249 Route to L:4.2[Line:10000>>2354455] sends Invite-OUT Send Req INVITE from 0.0.0.0:0 tid=756d8154373aae29 Call-ID=NGFmMTAzNTg0ZDk5MTU4NTA2MDQ4NDM3YzdiOWQxY2Q.:
    INVITE sip:2354455@10.16.0.246:5060 SIP/2.0
    Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-756d8154373aae29-1---d8754z-;rport
    Max-Forwards: 70
    Contact: <sip:14425546457@172.18.132.1:5060>
    To: <sip:2354455@10.16.0.246:5060>
    From: "14425546457"<sip:14425546457@172.18.132.1:5060>;tag=541a4225
    Call-ID: NGFmMTAzNTg0ZDk5MTU4NTA2MDQ4NDM3YzdiOWQxY2Q.
    CSeq: 1 INVITE
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
    Content-Type: application/sdp
    Supported: replaces
    Content-Length: 253
    Remote-Party-ID: "14425546457"<sip:14425546457@10.16.0.246:5060>;party=calling
    v=0
    o=3cxPS 49408901120 474241564673 IN IP4 172.18.132.1
    s=3cxPS Audio call
    c=IN IP4 172.18.132.1
    t=0 0
    m=audio 7014 RTP/AVP 0 8 3 101
    a=rtpmap:0 PCMU/8000
    a=rtpmap:8 PCMA/8000
    a=rtpmap:3 GSM/8000
    a=rtpmap:101 telephone-event/8000
    a=sendrecv
    19-Jun-2015 16:44:13.243 Outbound URI is used: sip:14425546457@10.16.0.246:5060
    19-Jun-2015 16:44:13.243 SLA is globally disabled
    19-Jun-2015 16:44:13.243 Added leg L:4.2[Line:10000>>2354455]
    19-Jun-2015 16:44:13.198 [Flow] Call(C:4): making call from L:4.1[Extn] to T:Line:10000>>2354455@[Dev:sip:14425546457@10.16.0.246:5060]
    19-Jun-2015 16:44:13.198 [CM503027]: Call(C:4): From: Extn:6700 ("Jacklyn" <sip:6700@172.18.132.1:5060>) to T:Line:10000>>2354455@[Dev:sip:14425546457@10.16.0.246:5060]
    19-Jun-2015 16:44:13.198 [CM503004]: Call(C:4): Route 1: from L:4.1[Extn] to T:Line:10000>>2354455@[Dev:sip:14425546457@10.16.0.246:5060]
    19-Jun-2015 16:44:13.198 Line limit check: Current # of calls for line Lc:10000(@wtf[<sip:14425546457@10.16.0.246:5060>]) is 0; limit is 12
    19-Jun-2015 16:44:13.198 Call(C:4): Call from Extn:6700 to 92354455 matches outbound rule 'Rule for wtf'
    19-Jun-2015 16:44:13.198 [Flow] Call(C:4): has built target endpoint: Out#:>>Rule{Rule for wtf}>>92354455 for call from L:4.1[Extn]
    19-Jun-2015 16:44:13.198 [Flow] Target endpoint for 92354455 is Out#:>>Rule{Rule for wtf}>>92354455
    19-Jun-2015 16:44:13.198 Selected prefix: 9
    19-Jun-2015 16:44:13.198 Looking for outbound rule: dialed = [92354455], processed: [92354455]; from-ext:
    19-Jun-2015 16:44:13.198 [Flow] Building target endpoint to 92354455 from "Jacklyn" <sip:6700@172.18.132.1:5060>
    19-Jun-2015 16:44:13.198 [CM503010]: Call(C:4): Making route(s) from Extn:6700 to <sip:92354455@172.18.132.1:5060>
    19-Jun-2015 16:44:13.198 Remote SDP is set for leg L:4.1[Extn]
    19-Jun-2015 16:44:13.198 OnOffer from "Jacklyn"<sip:6700@172.18.132.1>;tag=1601723566
    19-Jun-2015 16:44:13.198 [CM505001]: Endpoint Extn:6700: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Yealink SIP-T48G 35.72.0.225] PBX contact: [sip:6700@172.18.132.1:5060]
    19-Jun-2015 16:44:13.197 Inbound DID: ''; Phonebook Name: ''
    19-Jun-2015 16:44:13.197 [CM500002]: Call(C:4): Info on incoming INVITE from Extn:6700:
    Invite-IN Recv Req INVITE from 172.18.132.13:5062 tid=1924022360 Call-ID=4240812910@172.18.132.13:
    INVITE sip:92354455@172.18.132.1 SIP/2.0
    Max-Forwards: 70
    Contact: <sip:6700@172.18.132.13:5062>
    CSeq: 2 INVITE
    Allow: INVITE, INFO, PRACK, ACK, BYE, CANCEL, OPTIONS, NOTIFY, REGISTER, SUBSCRIBE, REFER, PUBLISH, UPDATE, MESSAGE
    Proxy-Authorization: Digest username="6700",realm="3CXPhoneSystem",nonce="414d535c0b951e2d61:2c87dfec7162863931a8140b3c83d0e0",uri="sip:92354455@172.18.132.1",response="9fc8c95b712a5c239876f90d396bfe85",algorithm=MD5
    Supported: replaces
    User-Agent: Yealink SIP-T48G 35.72.0.225
    Allow-Events: talk, hold, conference, refer, check-sync
    Content-Length: 308
    v=0
    o=- 20003 20003 IN IP4 172.18.132.13
    s=SDP data
    c=IN IP4 172.18.132.13
    t=0 0
    m=audio 11786 RTP/AVP 0 8 18 9 101
    a=rtpmap:18 G729/8000
    a=fmtp:18 annexb=no
    a=rtpmap:9 G722/8000
    a=fmtp:101 0-15
    a=ptime:20
    a=sendrecv
    19-Jun-2015 16:44:13.197 [CM503001]: Call(C:4): Incoming call from Extn:6700 to <sip:92354455@172.18.132.1:5060>
    19-Jun-2015 16:44:13.193 Outbound URI is used: sip:6700@172.18.132.13:5062
    19-Jun-2015 16:44:13.193 IncomingCall: C:4 from <sip:6700@172.18.132.1:5060> to <sip:92354455@172.18.132.1:5060>
    19-Jun-2015 16:44:13.193 Added leg L:C:4.1[No endpoint yet]
    19-Jun-2015 16:44:13.193 UasSession 716 started
    19-Jun-2015 16:44:13.193 Call from "Jacklyn"<sip:6700@172.18.132.1>;tag=1601723566 to <sip:92354455@172.18.132.1>;tag=8420fb4f
    19-Jun-2015 16:44:04.214 Currently active calls [none]
    19-Jun-2015 16:43:34.212 Currently active calls [none]
    19-Jun-2015 16:43:02.211 Currently active calls [none]
    19-Jun-2015 16:42:30.209 Currently active calls [none]
    19-Jun-2015 16:41:58.207 Currently active calls [none]
    19-Jun-2015 16:41:26.205 Currently active calls [none]
    19-Jun-2015 16:40:54.203 Currently active calls [none]
    10,763
    286
    Did this problem "just start", or has it been this way from the beginning. In other words, did something change on the network set-up/settings, that may be causing this?
    Have you run the 3CX Firewall Checker with success?
    Generally, when it's an incoming problem , with outgoing OK, then it is a routing issue, or perhaps a setting in the router. Listing what make/model router you are using may assist other in providing the (perhaps) required settings to have SIP work correctly.
