SIP phone D-Link DPH-140S
Discussion in '3CX Phone System - General' started by VladislavA, Jul 6, 2007.
  1. VladislavA
    Jun 9, 2007
    30
    I've tested basic functions SIP phone D-Link DPH-140S with 3CX (v3.0.1928) today.
    Just worked.
  2. 3CXsupport
    3CXsupport New Member
    Aug 21, 2006
    193
    Thanks for the leting us know !
    It's good to hear about the (less mentioned) successful experiences with the PBX too :)
  3. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Hi VladislavA,
    I would like to have more details for your test.
    Tested at LAN or over internet (NAT or direct)?
    3-way Conference?
    Call Transfer?
    Support config download from FTP, HTTP and TFTP?
  4. VladislavA
    Jun 9, 2007
    30
    The Hold button works fine.
    Call transfer is in testing now.
    I can't try 3-way conference because I have only one D-Link DPH-140S.
  5. VladislavA
    Jun 9, 2007
    30
    The Transfer button on DPH-140S doesn't work.
    Unsuccessful transfer attempt produces the record in the 3CX log:
    10:35:16.312 CallConf::eek:nIncoming [CM103002] Call(14): Incoming call from 112 (Ext.112) to sip:100@192.168.10.31:5060
    It
  6. VladislavA
    Jun 9, 2007
    30
    Bad thing 1
    Ethernet sockets are too weak. I forecast short life in production zone.
    Bad thing 2
    There is no Reset button at all. You can reset phone through standard web interface or by executing undocumented procedure (you can get it from D-Link technical support).
