SIP port change
Discussion in '3CX Phone System - General' started by ilkeryildiz, Mar 4, 2007.
  1. ilkeryildiz
    Jan 7, 2007
    26
    How can i change sip port 5060 to another port 3cx system?
  2. Anonymous
    Anonymous Guest
    Sip ports are defined in the gateway settings.
    You find this under the lines section on the left hand side.
  3. ilkeryildiz
    Jan 7, 2007
    26
    3cx system listen sip port 5060 for remote client.
    I want change different port.
  4. Anonymous
    Anonymous Guest
    Is'nt that what you do in the gateway setup? that is where you specify the port to use? (eg listen and send)
  5. 3CXsupport
    3CXsupport New Member
    Aug 21, 2006
    193
    Hi currently we only support the set up of the PBX on port 5060.
    This mean the pbx can only listen on 5060, it CAN however comunicate with VoIP providers that do not work on port 5060, and for example 5061.
