SIP Protocol Timeout Value for Firewall
Discussion in '3CX Phone System - General' started by loyer, Feb 12, 2018.
  1. loyer
    May 5, 2016
    43
    Hi Everyone,
    My firewall (Juniper SSG-320M) sets the default sip (and any udp protocol) session timeout to 60 seconds. I notice in my firewall logs that I see SIP connections open and then close every 60 seconds and then reopen again for each of my remote SIP phones.
    Just wondering if anyone knows if I should increase the sip session timeout? And if so, to how much .... 120 seconds?
    Most of the phones I am using are Yealink T48S and I checked their configurations and they seem to have keep alives enabled every 15 seconds. I would think that would keep the UDP connection open.... but actually maybe not? Are keep alives only for TCP?
    Thank you.
